- Mar 1, 2016
- 94
- 19
I am doing some wiring and might need another power supply for my Huisun PTZ cam. I already have a good POE switch and thought I was ordering a Huisun with POE but got stiffed by Huisun and was sent a non POE unit.
OK, not going to stomp my feet at Huisun and get this fixed.
I have a 12V 2.5A power supply but it is dubious it will work over long Cat5e run. Tested it with 200 ft of cat5e good cable and it does not provide enough power. Not sure of it is volts or watts...
Was looking around for another power supply and found these 48V POE to 12V POE converters and thought that would be good to use my POE switch and knock it down to 12V with a converter right at the camera.
So any one use one of these?
http://www.panoptictechnology.com/network-smart-adapters/
These guys are supposed to have them but the unit shown has no 12V pigtail
http://www.titanwirelessonline.com/Smart-Adapter-48V-to-12V-p/pe-ipaf4512-pan.htm
Robert
Robert
