- Mar 9, 2014
- 36,891
- 21,408
4.8.1 - September 20, 2018
- If you are creating sub-folders by overriding the recording paths on the Record tab in camera properties, those folders will be automatically removed once the last item has been deleted.
- Camera frame windows now are automatically closed if all cameras are hidden or removed from the frame.
- Push notifications to Android are now marked as Priority so that they may now be capable of waking the device in a low-power mode.
- A status window display issue has been corrected. When using Windows font/app scaling the Tab control would be cutoff or overwritten.
- A "Rotate 90" degree option has been added to the PTZ tab
