- Mar 9, 2014
- 36,891
- 21,408
4.8.0 - September 10, 2018
- New make/model selections for Nest/Dropcam now allow you to specify only the "public page" URL. The software will automatically use this to obtain the HTTPS/JPEG URL or UUID for RTMPS streaming. The public page requires no user/password, but is not actually "public" unless you distribute your UUID. When supported by your camera, the RTMPS option will provide a superior resolution, frame rate, and audio.
- Every password entry field now has a corresponding password "peak" eye icon.
- The web server has now disabled HTTP pipelining which was leading to issues with improper/incomplete responses under some load conditions. This scheme also has been deprecated by HTTP/2.
- A memory leak bug on the camera properties page has been corrected.
