- Mar 9, 2014
- 36,891
- 21,408
4.7.5 - May 23, 2018
- A new option on the Webcast tab in camera properties (default ON) allows you to add camera overlays such as the timestamp when viewing direct-to-disc BVR video files via the UI3 interface or phone client apps.
- The JPEG quality setting has been removed from the Webcast tab. JPEG encoding will now use the value set for "encoder profiles" on the Options/Web server/Advanced window. This now allows you to restrict JPEG streaming quality per user and per stream number rather than per individual camera, bringing it into line with the way in which other encoding methods have been operating.
- Audio delay option added to Audio tab in camera properties. It may be necessary to use this if you are mating IP video with DirectShow audio.
- The "limit decoding unless required" option will now work with RTMP sources like ReoLink
