4.7.1 - March 6, 2018
fenderman
Staff member
Mar 9, 2014
36,891
21,408
  • The Options/DIO page has been updated once again. You may now assign an /admin action to each DIO input bit separately as it's set and reset. To emulate the previous feature where the traffic signal could be controlled with a single input bit, use "signal=0" to set the signal red, and "signal=1" for green.
  • Also on this page you may now force-set up to 8 SeaLevel outputs.
  • Incompatible HW decoding will now be caught and logged, and the setting automatically reset to No.
  • Bugs resulting from mixed-case group names should now be resolved.
Reactions: fishtek
