Got 4 1080p cams and want to add 4 4k cams in blue iris, but the cpu (i5 4460) is commiting suicide aws
All direct to disc and wired ethernet
all set on 15 frames
So, time to upgrade I suppose?
cpu, i7 with HT like series 600 or higher? or maybe a Ryzen setup? (mini itx or equal so only mb, cpu and ram is target for change)
Thinking of an SSD 512Gb and 10 days retention. should be enough?
Budget, well as low as possible
Thanks
Thanks
