4.0 AI New models IPC-HX5XXX-Volt_MultiLang_PN_Stream3_V2.800.0000000.11.R.191230
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,110
26,554
HONGKONG
This is the latest new firmware for these models.
Attention,
the firmware support these models only, please make sure you are use the right firmware for the right models and make a default after you finish the updating.
IPC-T5241H-AS-PV
IPC-B5442E-ZE
IPC-B5442E-ZE
IPC-D5442E-ZE
IPC-D5442E-Z4E
IPC-HFW5241E-Z12E
IPC-HFW5241E-ZE
IPC-HFW5241E-Z5E
IPC-HDPW5442GP-Z
IPC-HFW5241T-AS-PV
IPC-HFW5541TP-AS-PV
IPC-HDW5541HP-AS-PV
Bug fixed:
1. Fix the problem that the face algorithm fails when there is a lot of screen targets;
2. Remove the atmospheric light intensity mode option in the fog;
3. Fix the abnormal problem of noise filtering algorithm;
Thanks to the volunteers' testing for this version.
Andy
Hi Andy, thanks ! Do you know if is available the logo version as well, of this firmware ?
that was quick, thanks. is this the correct forum for the latest firmware? i'm seeing some firmware on dahua wiki also.
i guess, i see a dropbox link which saves to my computer. i just searched for firmware for my N22AL12 and found a newer version on a USA dahua wiki page. i downloaded it, and tried to install it. the camera froze for minute then came back. I manually rebooted the camera and checked the firmware and it didn't take the new firmware.
My current version of my cam New Model IPC-T5241H-AS-PV 2MP from Andy is System Version V2.800.0000000.10.R, Build Date: 2019-11-18
I am a little confused on why people are asking for a logo version? Do not want to update mine just incase I have a different version can anyone clarify to me what the difference is or which version of the camera I have thanks.
Also want to know what difference is in this firmware.
There is no difference between, the logo version and the non-logo version other than.....the Dahua logo.
If it's not broke, don't fix it.
Reactions: sdkid and ANTH040
I see that there is new firmware for my IPC-HDW5541H-AS-PV
Still not satisfied with the IVS triggers and maybe this will help. The release notes link back to the product page so don't know what is fixed.
Can I apply this firmware?
EDIT: Applied the new firmware. Camera still running; going to test the IVS rules :)
EDIT2: I saw this is just the "logo" software version of the camera....:oops:
Greetings!
I just purchased and installed the IPC-B5442E-ZE from Andy. Should I be upgrading to the "Logo" vesion? Is the "Logo" version the branded hardware? Which firmware is is the latest that I should be upgrading to?
For example, is this the latest firmware, General_IPC-HX5XXX-Volt_MultiLang_PN_Stream3_V2.800.0000000.11.R.191230.bin, from 12/30/2019?
Thank you
Greetings!
Thank you
If you are not having any noticeable issues, then don't upgrade. If it's not broke, don't fix it.
The logo version only adds the Dahua branding to the setup screens. There is nothing else added.
Thank you! If I understand correctly, there is no new "non-logo" software update since 12/30.
I'm trying to get some IVS functionality to work and am not getting the expected results. Is there a guide to configure IVS on the camera and not on the NVR, that has a similar interface to this camera?
