- Mar 9, 2014
- 36,891
- 21,408
4.0.2 - March 12, 2015
- The Windows Performance Data Helper (PDH) is now used to get CPU usage time for display within the software. This should provide more accurate information on multiple-physical-processor systems.
- Flash/RTMP streaming to UStream should now be functional on 64-bit systems
- Algorithms used to detect key frames from IP cameras have been modified, which should fix Direct-to-Disc recording issues experienced with certain H.264 cameras on 64-bit systems
- A bug causing the video in WM "pull" webcasting to freeze after 7 minutes has been fixed
- Audio/video sync has been improved for WM webcasting, although better overall system A/V sync improvements are yet to come.
- If a camera unexpectedly changed resolution during streaming, it was possible for it to go into an extended No Signal state
- Digital zoom position in the Viewer window is now persistent through the opening of clips of the same resolution. However it will reset when the viewer window is closed and re-opened.
- Time elapsed and remaining are now displayed in the Viewer window when a single file is open
