ServiceXp Getting the hang of it Feb 12, 2015 213 18 USA Apr 27, 2015 #1 Looking for a ready made, BI compatible IP Camera that I can install inside a FlashForge Creator Pro. The left front vertical corner rail is empty, so I'm thinking I could fit a small one there.. (Not really interested in building one)
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,225 15,128 USA Apr 27, 2015 #2 How about this one? http://www.ipcamtalk.com/showthread...i-720P-HD-IP-Cam-(The-Cheapest-IP-Cam-So-Far-!!) Small, cheap, 1MP, lens should be focusable easily to the very short distance required.
ServiceXp Getting the hang of it Feb 12, 2015 213 18 USA Apr 27, 2015 #3 How about this one? It looks like it's almost the same? As an Amazon Associate IPCamTalk earns from qualifying purchases.
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,225 15,128 USA Apr 27, 2015 #4 Yeah, that looks the same to me. Not sure if the hardware is identical or not but it should work for the same purpose. The first (best rated) review describes how to add it to Blue Iris.
