32 NVR with 5 Ubiquiti ac 23
rocot0
Nov 25, 2017
4
Hi .. I'm new to the forum, and I do not know where I should write. but I have some questions, to see if someone can help me .. I have 5 Ubiquiti Litebeam AC 23.. 1 as an access point and the other 4 as a station .. for a project of 32 cameras in buildings separated ..the connection is fine, but I can only see 1 camera, each ubiquiti antenna has a POE switch with 8 ports... many thanks in advance and I appreciate any help
1) By the "...connection is fine", please define.
2) How do you view / manage the cameras (or in this case, the '1' camera) ?
3) Assuming the AP and each station has its own static IP, has each cam also been assigned a unique static IP on the same subnet?
thanks for your time, the connection between the access point and the stations are ok, checking one by one they see each other and the access point sees and receives from the other 4 but from those 4 stations, but I can only see one camera, the NVR has the NIC 192.168 .254.1 and the camera that I can see has 192.168.254.2 and the ones that are not 192.168.254.3..4 ...but I have not modified any ip address
What brand/model of cams are you using? You can confirm each cam shows LAN activity?
Thank you very much for the concern and help, I already got the connection and it is working ok, 32 cameras in 8 buildings, each building with 8 and a POE switch .. thank you
Great!
Reactions: rocot0
