- Jan 20, 2015
- 2
- 0
Hi guys, new member here! As a light introduction, I manage IT for a small corporation and have years of experience in PC hardware and network admin, but new to the surveillance world.
Our plant here is quite large and yet still has no camera system in place, I've been here for a couple years now so it's time to change that. We want to put in 30-35 cameras Indoor/Outdoor to be used with motion detection where it can be used and reviewed at a later time on a case-by-case basis. So very little need for live viewing. Looking at storing around 2 weeks of footage on each cam. From what i've found, POE IP cams somewhere in the 2-3MP range at 10fps should look ok. I'd like to use BlueIris software as it seems to check all my boxes. My concern is the CPU requirement with this many cams on one machine at 2-3MP/10fps with BI. Is this possible with for example an i7-5820k and 16G's ram? From what i'm reading, the CPU overhead is drastic with BI.
Any general recommendations about running this many 2-3MP cams on a homemade PC NVR are welcome as well. For storage I'll probably be running 4-6 WD Purple drives in raid 5
Thank you!
Thank you!
