2nd or 3rd video stream from cams - off when not using?
marklyn
Pulling my weight
Jun 13, 2015
506
133
Curious thought I had today.
If your camera has 3 video streams and you only use 1 (primary), are the other two video streams still "sending" video?
Assuming your camera has the ability to disable the sub streams, is it wise to do this if you're not using them, or does it really matter in regard to bandwidth.
Not sure I'm asking the question correctly but hope someone understands what I'm trying to say.
Most cameras do have the ability to disable sub-streams.
Yes. If you are not using them it is wise to disable them.
