- May 16, 2017
- 2
- 0
Okay,
This is my 2nd try at getting a wireless camera setup working. My 1st attempt is sin components around the house unable to connect with each other.. but more on that at the bottom in parenthesis. Let's deal with this 2nd NVR first if possible..
My Goal is to set this new one up so that I can view the cameras through Blue Iris either with or without the included NVR, whichever works.
Here is a link to the NVR Camera KIT
Please tell me if this is possible, and if so, how. Thanks in advance
(((((((((((((((I have a similar item I purchased that no longer works because I changed the SSID in the NVR from the factory setting without memorizing it. This instantly severed the connections with the wireless cameras, which I guess were programmed for that particular SSID. Simple solution would be to change the setting in the cameras right?...... but no way to communicate with the wireless cameras. They even have Ethernet dongles, but don't even show up when connected directly to switch or router. The NVR has no LAN ports. I can access the NVR just fine. They are not ONVIF compatible from my understanding and I don't have link to specs. The NVR came programmed to operate as a subnet but don't recall address.)))))))))))))))))
