2nd Camera Question?
jasoncmt24
Feb 7, 2015
27
I bought a camera from China last week and now looking to get my 2nd camera. Even though I really like my first cams features and quality I want to buy one from the US this time. I currently do not use a nvr I go direct to PC and was wondering what I need to look for to make sure the new cam will be compatible? The first cam is onvif 2.2 should I look for onvif cams only for my second?
Thanks in Advance.
It depends entirely on what software you use on the PC. Also, a lot of the cameras you can buy from the USA are the same as the ones you buy from China, but they just cost more because of the middleman in the USA.
Sorry read that wrong. The software that came with the camera is called network video monitoring. I like it a lot. The camera is pretty amazing for only $279 I must admit. I would get another one since it got to my house in 3 days from China but I need something with more than a 10X zoom.
