865/5000
Hello, I bought about 3 years ago camera 2cd2532f-is Hikvision, on the Polish website and ....... about, as it resulted from the description from the Polish Dystribution,
It had a version of the v5.1.2 software, I was cheered for upgrade from the HIKVISION website, I downloaded the correct Baseline Firmware Firmware_IPC_R0 series_En_V5.2.0 140721 upgrade, it sounded correctly (through the browser), and 100% stopped and hung up.
After the serial number today at the HIKVISION distributor I find out that the camera is not from PL, but from China.
The camera can be said to be dead, the DVR can not be found (NO LINK) only by connecting directly on the PoE switch and sending it to the PC SADAP program finds it as DS-2CD-Min-System0120140521CCR ............ you can not change HTTP ports.
Is it possible to put some life into the old settings or a camera for trash?
