2CD2387G2 - Third Stream
craigscott
Mar 12, 2021
20
11
UK
Hi, Hope you all can help.
I have recently purchased some DS-2CD2387G2-LSU/SL (C) Cameras, the specifications clearly show there is a third stream (1080) that is available. I understand the NVR I have only supports two streams, however I'm now trying to enable the third stream so I can utilise it with Blue Iris.
Have seen quite a few threads about having to enable the third stream in the settings of the actual camera - only I cannot find it at all, I have played around with all the encoding and quality settings of the main stream etc to make it appear - but nothing.
Can something help?!
Thank you in advance,
Craig
If you're trying to get the third stream through NVR, it probably won't work as your NVR only supports main- & substream.
Directly through the cam, yes.
I didn't have to enable the thirdstream in my cam (DS-2CD3386G2-IS, maybe depends on model), i could directly access it for example by rtsp://192.168.1.13:554/Streaming/Channels/103/
You can simply pull the mainstream and substream from the NVR into Blue Iris - y I y don't need the 3rd stream for it.
Simply go to BI and type in the IP address of the NVR along with user and password and hit the find/inspect button and let BI do its thing.
Then repeat except when you add the next camera, change on that screen camera number from 1 to 2. Repeat for the number of cameras you have.
To access the third stream setting you need to place the VCA resources setting into “Monitoring” mode.
Only then will you get access to 3rd stream In the video/audio menu.
Reactions: yurgh
I was looking everywhere to try get the Third Stream to show up. But these days the UI is a little different, and the VCA is now "hiding" on the main menu on the left. Somehow I kept missing it, figuring it was just a graphic heavy version of other settings under Configuration.
Turns out it's not, and it's the only place where you can change the VCA from Smart Event to Monitoring. (after a reboot, then my third stream came up.
Just thought I'd leave this, incase there is another crazy person out there like me with the newer UI, and overlooking VCA menu.
