The owner of this company used to hang out on the forum and post great videos...he hasnt been around in a few years. @bababouy https://nighthawkmonitoring.comI'm curious if anyone here can recommend or uses a 24/7 security camera monitoring company and if so can you use your current nvr and cameras or do they require use of their systems?
They use your equipment.
I have never used his services but it appears like they were doing a great job. Search his posts for some interesting video.
Thanks Tony, Good suggestions.I think bababouy was in southern FL, maybe even close to the Keys. I miss his videos on IPCT.
If you get insufficient responses to your post, consider looking here ==>> Better Business Bureau
At the above link I suggest typing in the category "alarm monitoring" and "BBB Accredited Only"; put in the name of your city and state then click on "Search."
Maybe look also in several different categories pertaining to surveillance, CCTV, alarms, etc.
I just saw this and your post came to mind. I dont know what the other guys charge for monitoring but ring has a service that is compatible with onvif cameras. its 99 monthly plus it requires a ring alarm and pro subscription but is still likely much cheaper than the others. It appears that rather than live monitor 24/7 they wait for a motion alert for a human to begin monitoring ....throwing it out there..I'm curious if anyone here can recommend or uses a 24/7 security camera monitoring company and if so can you use your current nvr and cameras or do they require use of their systems?
Oh wow, I didnt know they supported ONVIF! At the very least, it will be interesting to look into. NHM never did reply to my email..I just saw this and your post came to mind. I dont know what the other guys charge for monitoring but ring has a service that is compatible with onvif cameras. its 99 monthly plus it requires a ring alarm and pro subscription but is still likely much cheaper than the others. It appears that rather than live monitor 24/7 they wait for a motion alert for a human to begin monitoring ....throwing it out there..
The benefits of Ring, now for your ONVIF-compatible cameras
See and control all of your security devices in one place, and so much more, when you connect ONVIF-compatible cameras to the Ring App.ring.com
