23AWG Cat 6 RJ45 passthrough connector recommendation
dubber
Getting comfortable
Oct 4, 2022
226
350
Toronto
Hi All
Can anyone recommend a reliable source to buy rj45 cat 6 23awg connector please?
I bought one from Newegg and either I'm doing it wrong or the connectors are cheap. I tried 2x and both times it did not work.
I used cable tester and it shows it's good. When I plug into PC to test connection, got no Internet connection.
I tried both A and B wire types. Same issue lol
I don't want to "try" my luck and buy one from Amazon and keep wasting money.
I wonder if the latest batch of Klein connectors have had the hole opened up to 1.02MM? It seems to me that it is now even easier to slide the wires through the connector than say a couple of boxes ago.
I bought the connectors recommended in this thread
Hopefully it will fit 23awg wires :)
What I do to help matters is straighten the wires as much as possible. They come in twisted pairs and are kind of kinky. I also leave the wires around 1.75" to maybe 2" long. IMHO this also helps things. I also cut the spine as far back as I can.
Reactions: JDreaming
