1. So the market has about 6 or 10 brands of these pendant dome cameras, which all seam pretty comparable, All around $170 to $300
I tried a few and the Jennov, the cheapest had pretty bad Ai, the JideTech had a little better, but WHY are these detecting PARKED cars?
The rectangle keeps detecting it, AND the Jide WAS zooming in and following humans when detecting. Changed some settings, and I cant get it back to do it.
They each have 2way Audio.
And some of the options to Ai detect, bikes vs E-bikes? Whats that about. And some features the sw states is not even available.
So these Ai features are looking to me as some sort of gimmick, in a wide use situation. Maybe good for specifics for front door, sure? But they are huge for front door, so?
2. I was looking for such a zoom and versatile camera for License Plates, BUT, trying the different IR settings, I could not get these to get any night time plates.
And the JideTech is CONSTANTLY focus correcting, and its not slow, BUT, it still isnt ideal to not have manual focus, as it misses pretty much everything with night shutter speeds, etc. Even a little rain gets these cams to be out of focus.
So, I am thinking, I have another 10x zoom, which is enough, and is a bullet cam, that I think might do better. So, we shall see on that front.
3. ANOTHER MAJOR issue I am noticing camera makers make a mistake on....
The degree they allow the camera to tilt UP.
So just a couple out of the 10 brands that have these PTZ 20X domes, have a 95degree up tilt. Problem is, from a single story vantage, once you zoom in, you are looking way down. They need to allow UP, so you can see higher up, AND if you want watch the skies or mountains around, etc.
So that limitation I find me going for other models of cameras. The PTZ with bullet style, did allow for up tilt, yet the Inesun I had which WAS great, did stop tilting up, and eventually that PanTilt motor died.
What are some of your thoughts on the different points I make?
