Is there advantage or disadvantage using 2048x1536? I an just playing around, I did notice the viewing angle changed but that's about it.
The change of viewing angle is due to the different image ratios 2048/1536=1.33 and 1920/1080=1.11. Therefore there is no change of optical viewing angle due to the lens which of course is fixed, it is only a digital change of view. The image sensor in the camera is the same and its native resolution is 2048x1536.
MaxIcon on Cam-it.org said:The Hik sensor appears to be about 2.5MP, with sensor resolution of 1275x1920, for an aspect ratio of 3:2. Assuming the 1080p image is true 1080p, the 3MP image is actually a 2.2MP image, scaled up 120% to give an apparent 3.2MP image (note that MP scales with the square of the horizontal and vertical resolution).
I set mine at the full 3 MP. Comparing some images taken at 3 MP vs 1080P I could see a definite clarity difference. Further to aster1x's post, if you don't want to use too much bandwidth, just lower the frame rate. I'd rather have 3MP @ 15 FPS than 2 MP @ 24FPS. In fact, I'd rather have 9 MP @ 5 FPS than either of those![]()
