2025 EmpireTech Product Release
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,361
27,421
HONGKONG
Hey Guys,
Today we release the latest new Cameras and NVR. This is the link for checking all. ProColor Series Camera The turret Pro Cameras start the selling on Monday, will be shipped in 1 week after the order made.
  • The New 5 series Pro dual illumination (IR and LED )Cameras, We call it Pro Color. It comes with the latest new Tech on full color technology and Smart Large Scale Model. It comes with IPC-T54PRO-AS, IPC-T54PRO-ZE, IPC-B54PRO-Z4E,IPC-B58PRO-Z4E. The Large-Scale AI Model places visual analysis at its core, integrating multimodal capabilities and embedding deep industry expertise to create a large model tailored for diverse application scenarios. Attached file has the details for further checking.
  • 5 Series XI-Pro NVRs, this NVR will provide the great support on the Large Scale AI Model. Attached file has the details. We also have some update for the current 5 series too, update to S2.
  • New 45X PTZ with Wizetracking technology. The initial version of this algorithm is specifically optimized for complex occlusion scenarios and posture changes in target form factors.
Will also Add a Laser 42X ZOOM PTZ , 600meters one.
What is Large Scale Models? I think The trend for the future of the camera industry will be a small home system can be a platform. You can design it yourself to make the system a very strong one.
About Review.
I will go on inviting some guys here to make some review about the product after we get the stocks. Like we did before. Thanks for all guys support and waiting on these new things.
The Old models go on selling, they are still good.
Most interesting 2 slides - what new 5xxx-PRO NVRs will have performance/functionality...
AI performance it's double what 608-XI have now, plus new WizSeek functionality (next to AcuPick one) and modern firmware with latest UI..
2 AI engines inside (like 2 AI processors), one for running WizSeek/AcuPick for all channels, second for extra 8 AI channels of processing Face Recognition/Video Meta Data/AcuPick (or 16 IVS) for older cams which don't have that function
512 mbit/s of bandwidth, 40 channels of decoding 1080p@30fps (actual models have 32)..
Andy what price and release date?
Wait to Oct, price i still not have, but will be around 30% higher than the -xi model that we are selling now.
Left one is the IPC-B54PRO-Z4E, right one is the IPC-B54IR-Z4E
As I repeated many times in the past - good F1.0 varifocal (zoom) optics are much bigger than F1.6 or F1.8 ones are..
New varifocal turret T54PRO-ZE is monstrous next to old T54IR-AS/-ZE.. the same with bullets...
Plus they fit speaker/siren and quadruple hybrid lights into all models (even smaller fixed turret).
It's first 5-series camera line, where we do not have a large difference in LEDs performance or aux list (mic, speaker) between bullet and turret, fixed and varifocal.
One more thing - Andy put new 5xxx-EI2 recorders on his shop.. They are called AI-S2 (wrrrrr Andy we must talk more about Your products model names :)) and they are only 20-40$ more comparing to old 5xxx-EI in the same configurations (channels output, POE, HDDs)...
They look identical - but they are not! There is 2x more AI performance limits (SMD/IVS/FD/FR) on new -EI2 (AI-S2) models and those new models can add Video Meta Data or AcuPick to 4 OLD cameras without those functions (old NVR didn't had that functions).
And Video Meta Data on this models supports car plates - so You can add cheap ANPR (OCR for car plates) with search functions up to 4 cams (depending of how much other AI functions You use)!!!
Enabling AcuPick on 5xxx-EI2 don't disable other AI functions like on old 5xxx-EI...
If you're planning to buy/upgrade an NVR, don't make the mistake of choosing a OLD model.
Especially since the old one won't be getting new features (and will be EOL - it's almost 3 years old NVR).
The new one will likely get several (usually 2-4) MAJOR firmware upgrades with new features over the next 2-3 years of product lifecycle.
