2021 New Product From Dahua
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,110
26,554
HONGKONG
Hey Guys
Get some docs from dahua for the new product. I post here about some key point here, can't share the docs right now. Sorry!
1. Lite cams no big differene, will update to S3. Will have some 5MP out.
2. Pro models Cams update to 3.0 SMD(Will send latest fw for update later when received.) Mainly on 52,54, 58 Series, IPC-T5442T-ZE, IPC-T5442TM-AS Starlight+<=0.003Lux , AI:FD with attributes/People counting/IVS/SMD 3.0/object detection 1.0
3. Ultra smart Series cams(Ultra Smart) will have 8-56MM lens, 4MP.8MP, 12MP has big update. ANPR camera will have more choice.
Resolution : 4MP@50/60fps,8MP@25/30fps,12MP@25/30fps Lens:P-iris,8~56mm TPM encryption Scenario AI functions: (1)Face and Body Detection:Face detection and human body metadata are enabled at the same time; Personal Protective Equipment Detection. (2)Video Metadata:Support direction detection and quantity statistics (3)Face Recognition:50,000 faces library, support Stranger Mode , support Accurate flow statistics (4)CNN Object Detection (5)IVS Others: 5 streams , 65℃; ePoE
3. Full Color Motorized lens. 4K turret/bullet also will come out.
• Vari-focal, 2.7-12mm;F1.2; • LED illuminator • AI functions: Perimeter protection /FD/People counting
4.PTZ, has some monsters out. 60X Zoom ultra smart.
4K PTZ with 1/1.2cmos 40x 42x ZOOM.
A MINI PTZ.
Yes sir, and thank you for posting them. One day when I grow up a smart PTZ will I have....:)
I will be curious about the multi-lens camera. On the surface, it doesn't make sense. I assume that it has two sensors, not just one 1/1.8"? Why would the panoramic and the detail segments use about the same focal length lens vs one being like 3mm (vs both being 8mm) and the other being much longer (32mm or even 56mm)? Wait and see i guess.
Yeah I’m trying to think of how I’d use that also...? Probably use the Pano as a spotter? or I guess really just takes the place of two cameras, overview and zoomed in?
Reactions: samplenhold
So will there be new models of the 5442 cams released or is the update just a new firmware?
Yes, move to the 3.0 SMD and the anti-parcel lost function will be added, i talked this before.
And 5442 bullet will have Z12E version.
o_Oo_Oo_Oo_Oo_O
Did I say exciting and wow?
2021 Dahua year look exciting. 8mp + 1/1,2" sweet!
I wouldn't get too excited. 8mp 1/1.2 isn't the same as 4mp 1/1.2.
I don't think anyone has ever posted one of these, this Chart probably ought to be in the Wiki, but for everyone, a Chart of Sensor Size vs Sensor Area and physical size:
Unfortunately, I couldn't find a comaprison chart with 1/1.2 as it's so new. Someone could modify the Chart above and slip it in! However, I found a non CCTV camera chart with 1/1.2 dimensions in amongst non CCTV sensor sizes:
Based on their figures, (there are slight discrepencies with above), 1/1.2" comes out at approximately 85mm2. So fits between 2/3" and 1" in size and nearer to 1".
I wonder how many realised it was that large!!! It's little wonder the low light performance has jumped so much.
As for resolution on the new 8mp 1/1.2 cameras, you're doubling pixel count from 4mp to 8mp. So, effectively halving the individual pixel area. Therefore 8mp 1/1.2 equates to around a 42mm2 die at 4mp if comparing individual pixel space which is for practical purposes the same as 1/1.8".
On that basis, I expect 1/1.2" at 4mp to be the way to go for 2021 at least unti we have another development such as 1" or even 35mm (1 1/3"). Who's crossing their fingers or other body parts.
