Hello, sorry for my poor English
I would like to connect two recorders so that one would transmit the image via HDMI to the TV in one room and the other downstairs in the other room also via HDMI to the TV.
and there is a problem with these two Hisseu recorders. One is an 8-channel POE IP recorder, the other is a 16-channel one without POE. I connected and configured two IP cameras on them (I set separate permanent IPs in each NVR), and in the live view (on the thumbnails or in the full image from each camera, the cameras are still framed. In the settings, I set the number of frames, compression, etc., but unfortunately it doesn't help it helps, only disconnecting one from the network helps, then the image is smooth on one turned on recorder, when I connect the second one, the image stops automatically on two NVRs, it is not smooth, the DHCP settings remain unchanged
What would you advise me? Will you help me ? I don't have the strength for it anymore.
