- Oct 13, 2014
- 10
- 0
I'm looking to start buying some cams. I would like to get 1 or 2 for now to mount above my garage door look at my driveway and front yard. I would like them to have decent night vision and be $200 or cheaper if possible and work with power over ethernet. Just to verify if they support POE I only need to run the ethernet cable correct?
What would you suggest?
Thanks
Thanks
