Howdy,
I am trying to set up a 16camera system(dahua NVR and 16 Hikvison cameras with 2 8+1 Poe switches). Right now I can only get the cameras to work on the first switch(they are daisy chaned). I want 12 cameras around the house and 4 around my detached garage. There is a preexisting cat5e outdoor cable ran between the two buildings. I did get the second switch to work with the cameras if I plugged it into a wifi range extender. The only problem with that is it totally messed up the wifi at the house(Cisco router/modem combo from Comcast). None of the laptops would connect, the apple computer kept saying the IP address was already in use, I know for a fact that none of the up addresses were used.
Back to the main question, how can I get my cameras to operate properly with the daisy chained switch? I was able to activate and modify the IP addresses/subnetmask of the cameras with the daisy changed switch. Also, if I plug a computer directly into the switch it will not connect to the internet.
