Hi folks,
Looking for some advice/opinions on a camera for a wide driveway out in the country (very dark). Looking to avoid colour night vision (the light is jarring when there's no street lights at all), so prefer IR (ideally > 100ft). It's a relatively long/wide driveway.
Previously had a wide angle 8MP amcrest with 165ft IR and it worked well until it suddenly stopped, (we think some sort of issue with a power cut/UPS not working).
I'd given up on matching that IR distance at my price point as i struggled to find any. I was about to pull the trigger on
Hikvision DS-2CD2386G2-IU after deciding on this over the Hikvision DS-2CD2383G2-IU (2.8mm on both).
However did some more reading and stumbled upon a post on here highlighting the lesser effectiveness of high MP at night. I changed my search to 4MP cameras but then found the sensors to be smaller which I'd also heard was not ideal, with 1/1.6 4mp being noted as good choice whereas I was just seeing 1/3 on my searches
Any suggestions on where I can look in this pricepoint for what I'm after or is the hikvision as good as I'll get it/compromise on the IR distance?
