The CPU consumption goes to 90-100% the moment I finished adding all 12 cameras, default frame rate, 20fps, I believe and bit rate of ~3000. Initially I had them on H.265 without hardware acceleration, changed to H.264 with HA, but no change in CPU.
System is i7-8700K, 32gb RAM.
Is this a problem related to memory leak? I understand memorial leak would cause cpu/ram usage go up GRADUALLY, therefore "leaking". Here my CPU stays at 90 to 100% pretty much right after I open BI. On the other hand, RAM usage is not too bad, not sure if it will creep up or not since my PC just halt when BI is opened, so I had to close BI.
