dastrix Getting the hang of it Aug 18, 2017 188 19 Jun 15, 2019 #1 Hi There, Looking for one that would pickup noise/audio from about 10 meters away. Will run this with a POE splitter/RCA coupler Any suggestions? Thank you
G grumpywilson Pulling my weight May 1, 2019 190 189 NJ Jun 15, 2019 #2 There is a thread on here I saw about a bullet mic that picked up good sound. I forget what the title of it was.
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,886 14,482 USA Jun 16, 2019 #4 I have one of those. It is better than the built-in mics in starlight cams for sure. You just need a cam that has an audio input, and 12v power for the mic.
dastrix Getting the hang of it Aug 18, 2017 188 19 Jun 16, 2019 #5 hi bp2008, which camera do you use it with? Finding a hard time finding a camera like the 5231R-ZE which has audio input
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,886 14,482 USA Jun 16, 2019 #6 I use it with IPC-HFW5231E-Z5. This is a fairly old list now but it shows that a lot of models have an audio hookup: Dahua 2MP Starlight Lineup Reactions: dastrix
looney2ns IPCT Contributor Sep 25, 2016 16,322 24,230 Evansville, In. USA Jun 16, 2019 #7 Don't believe there are any turrets with Audio in, but a lot of the domes and bullets do. Check out the comparison chart: Product Selector Reactions: dastrix
looney2ns IPCT Contributor Sep 25, 2016 16,322 24,230 Evansville, In. USA Jun 25, 2019 #8 There is now a turret with audio in for a seperate mic: Review-OEM IPC-T5241H-AS-PV 2mp AI active deterrence cam
