- Jul 26, 2015
- 8
- 0
The next step in the journey is understanding the configuration for cameras - which I "think" is a problem I am encountering
So, right now I have the 2 cameras (described below) - and all seems well. However periodically I am getting a
No Signal - and then at the bottom a HTTP: 12002 Timeout
I haven't timed it yet - but it seems to be happening every 5 -10 minutes or so ?
UPDATE: The situation does correct itself after a minute or so . And I see in the settings where I could potentially reduce the amount of time before resolving .. Would like to understand why it is happening in the first place .
Did some research of the error code - I don't see anything definite in terms of Cause / Effect. Everything I have is on a Static IP - so not sure what the issue/challenge would be
Also, where is the "log file" for BlueIris for more info on the errors/conditions it hits ?
DELL i7-4790 16GB RAM, 4GB Card, 1 TB Disk - Wireless Connection
1 Trendnet - Wired - Static IP
1 Trendnet - Wireless - Static IP
