Are there any mfgs that make a switch like the heading? Unless I misunderstand, the switch uplink speed seems to be the bottleneck for surveillance systems. Am I wrong?
I was thinking of this as if all the cameras would be streaming at the same time, which is probably wrong. Thank you for your responses.Yes. Check out the UniFi line of switches. We use one of these in addition to some 8 port switches. Switch Pro 24
But, as @SouthernYankee wrote, cameras don’t need these speeds.
We don't use their cloud service; all are in house.Thanks for your time to respond and for not making fun of my ignorance guys. Regarding the Ubiquity products, I don't like having to use a third party cloud service for their products. Too bad their isn't an OpenWRT for switches. There isn't, is there?
Plenty of switches with what you want, but you really don't need 10G to your NVR unless you have an ungodly amount of cams
My core switch is an SX350X-24F with 24 x 10G SFP+ ports, and I haven't bothered to throw my NVR on there
I like cool things![]()
I have always had excellent luck with their ProSafe line. No hate here.My home network is 10GbE, so I wanted a couple switches that had 10GbE uplinks. I know there's a lot of hate for Netgear around here, but I went with their ProSAFE S3300-52X-PoE+. It's a 48-Port Gigabit Stackable Smart Switch with PoE+ and 4 10G uplinks. I bought them used on ebay for under $400 and they've been flawless. (I did replace the fans with Noctua since my network closet is in my office). I use one specifically for my Security VLAN. The Blue Iris computer is connected to one of the 10GbE uplinks and another uplink is connected to my 10GbE backbone switch.
