I’m looking for ideas on how to run 100ft of outdoor cat5E cable from a telephone pole to a building. I would like to use POE so I don’t need additional power to the camera. I think with this length, I will need some kind of strain relief or something to support it.
I have a red line from the pole to the approximate located on the building where it will attach. I will add a pole to the building so I have the height I need for clearance.
I have several of the cameras below which I will be using. I hope they will be sufficient at this distance. My goal is to eliminate the rear camera and the one by the front door which isn’t visible in the picture.
This is the camera I will be using:
Hikvision V5.3.0 DS-2CD2032F-I Replace DS-2CD2032-I 3MP 1080P Poe with SD Card Slot IR IP Network CCTV Camera Multi-language 4mm
