So I decided to add just one more IP camera to the mix but I only need 50-100' of ethernet cable to complete this project. I previously bought a 250' spool (Monoprice) to wire up the other cameras but what is left isn't enough for this camera. The problem I have now is that no one that I have seen sells decent quality Cat5e or Cat6 bulk in a 100' length. Most are 250' or more. I could purchase a 100' patch cable but the quality seems suspect for most of those or they just don't get into any detail about what cable they are actually using. Does anyone know if the Monoprice patch cables are the same quality as their bulk cable? Also looked at Home Depot and they have Cerrowire in 100' packaging but I'm still a bit concerned about their quality and not much is said about it. This run will be through the attic like the others where temps are often well over 100 degrees (Texas). So what would you guys recommend that I do?
