My machine was pretty taxed when running Blue Iris before the upgrade to 4.4.9.4, but still worked. Now that I upgraded to 4.4.9.4 I get the following:
1) 100% CPU on all 8 CPUs. Immediate crash if I tried to load the admin console.
2) I purchased the android app that used to work. Now I can't connect as it says the server is unreachable. In actuality I think it is timing out because if I test connecting to my Blue Iris server locally with a normal browser on a laptop it shows me the login screen but is super slow.
3) I was running Blue Iris as a service, so I had to deal with the CPU being maxed out right off the boot and then not having enough CPU cycles to go and kill the service. My machine is basically unusable if Blue Iris is running.
4) I finally had to go into safe mode and try and turn off "start as a service" there. I unchecked the box in the admin console.
5) Rebooted into normal mode. Blue Iris still started as a service.
6) Uninstalled and reinstalled 4.4.9.4. Same issues.
Here is the app crash info:
Problem signature:
Problem Event Name: APPCRASH
Application Name: BlueIris.exe
Application Version: 4.4.9.4
Application Timestamp: 584f2bc2
Fault Module Name: BlueIris.exe
Fault Module Version: 4.4.9.4
Fault Module Timestamp: 584f2bc2
Exception Code: c0000005
Exception Offset: 000000000008fd20
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: faa9
Additional Information 2: faa90cea74fc7cd82bbd962b8303a954
Additional Information 3: 10af
Additional Information 4: 10af8879cdeb35fdc13b33c8e2631ddf
I am running an Intel i7-2600K CPU @3.4GHz, 8 GB RAM, 500GB plus available on my drives, Intel i3000 video with the latest drivers. I am driving 9 DS-2CD2342WD-I Hikvision cameras. I am running Windows 7 SP1 with the most recent updates.
Problem signature:
Locale ID: 1033
