- Dec 6, 2017
- 11
- 3
I'm a brand new Blue Iris user. I've got (5) identical QCAM IP3M952E cameras configured. 4 of the 5 are displaying video fine. The 5th camera has totally corrupted video to the point it's unwatchable. The weird thing is that if I connect to the camera outside of BI through a web browser, the video displays fine. I've checked settings a few times and I'm pretty sure that everything is configured the same for all 5 cameras.
The one and only thing I have noticed so far is that on the problematic camera, the Max Frame Rate setting is different. I've tried setting it to 15 to match the other cameras, but it doesn't seem to "stick". Every time I pull up Camera Properties, it shows a different number there, usually between 31-60fps. I logged into the camera from a web browser and the max frame rate is set to 15fps there, so I'm not sure what's going on.
Any ideas on what I could check?
