Blue Iris - Version 4.3.7I just updated my BI about 15 minutes ago. I have 4 Dropcam Pros connected via rmtps and have been working for the last month (I'm new to BI). After the upgrade it says "No Signal" on all my cams? Any ideas?!? TIA
It is important to note that using dropcam with blue iris wastes tons of bandwidth (which might matter if you are metered) as the video gets sent to the cloud then back to you.
you failed to read the link i provided.I appreciate that, but I am not metered and that does not seem to help with my question? Any advice please?
Yes, I'm new to this forum, didn't know it was a link. I have since looked at it and changed my reply. Thanksyou failed to read the link i provided.
then find another vms...oh wait there is nothing that even comes close at this price point.I see the thread. That's disappointing. I'm new to BI, this is not a good sign for me.
Follow a few simple rules and you will NEVER have a problem. I run 20+ blue iris machines flawlessly..they just work
1) disable auto update
2) only update when you need a new feature or are having an issue
3) wait a few days after an update release to ensure folks are not reporting problems.
you need to run an older update file...that is why you should be manually downloading updates from the website so you have it...you can search the forum, others post dropbox links to older versions.How do I downgrade?
-export current settings (if you care for your current settings)
-De-activate current BI.
-Uninstall current BI
-Download ver 4.2.2.0 (one of the posters here may provide you with a dropbox link)
-install. Version 4.2.2.0 as demo, add cameras(import settings if you have any) and see if all works then activate with your license.
-make sure to disable auto-update and install.
Sent from my iPhone using Tapatalk Pro
