Ok, so here it goes.
Btw, for those interested, writing 0x1 to 0x200f004c will make the doorbell ring. Unfortunately, when you hold the doorbell, the register won't stay 0x1, making it a bit more difficult to hookup an old chime.
Would it be possible to do a patch to enable shell access through Ethernet? That way you can mess about with the thing without having to have the serial interface connected all the time.
I'm also wondering if re-compiling the decompiled code is going to result in a functioning binary. On x86 Windows systems that's often not the case, how about on something like this? That way it might be easier to change or add functionality to this thing.
Cleanest solution is to write a program that uses mmap() and monitors the memory location. If 0x01 is written there, the program can open a TCP connection to a server on your monitoring system. From there on you can control a cheap USB relay that powers the chime for a certain time interval.Awesome, thanks for all the detail. Gonna have to try that sometime.
Something else I and I'm sure others would be interested in would be to be able to reliably detect a doorbell press just by listening to the network traffic coming from the doorbell. If you find a way to make that happen please let us know. At the moment the only solution for that to have been shown working is to sniff the 433Mhz wireless signal but that requires extra hardware to do the sniffing. Plus the 433Mhz connection is not always 100% reliable it seems.
#!/bin/sh
tcpsvd -vE 0.0.0.0 21 ftpd -w / &
mount /dev/mmcblk0p1 /mnt/disc1
/mnt/disc1/patched/npc2 &
PID=`/mnt/disc1/busybox pgrep npc2`
/mnt/disc1/busybox mkfifo /tmp/npc.log
/mnt/disc1/notify -i IP -p 31337 -f /tmp/npc.log -m 222222222222 &
/mnt/disc1/reredirect -m /tmp/npc.log $PID
	#include <stdio.h>
#include <fcntl.h>
#include <stdlib.h>
#include <unistd.h>
#include <stdint.h>
#include <string.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <netinet/in.h>
#include "include/iv.h"
#ifndef BUFSIZE
#define BUFSIZE 4096
#endif
#define RING "RINGDINGDING"
#define DIE(x) { fprintf(stderr, "%s", (x)); exit(EXIT_FAILURE); }
struct callback_info
    char *message;
    struct iv_fd fifo;
    struct sockaddr_in addr;
static void send_ring_cmd(struct callback_info *ci)
    int sock;
    if ((sock = socket(AF_INET, SOCK_STREAM, 0)) < 0)
        perror("Cannot open socket, maybe later...");
        return;
    if (connect(sock, (struct sockaddr *)&(ci->addr), sizeof(struct sockaddr))
        < 0)
        perror("Cannot connect to target, maybe later...");
        return;
    send(sock, RING, strlen(RING), 0);
    close(sock);
static void fifo_callback(void *_ci)
    int len;
    char buf[BUFSIZE];
    struct callback_info *ci;
    memset(buf, 0x00, sizeof(buf));
    ci = (struct callback_info*)_ci;
    len = read(ci->fifo.fd, buf, sizeof(buf));
    if (len <= 0)
        if (len < 0)
            if (errno == EAGAIN)
                return;
            perror("Error reading from fifo: ");
        exit(EXIT_FAILURE);
    if (strstr(buf, ci->message) != NULL)
        send_ring_cmd(ci);
static void print_banner()
    fprintf(stderr, "Usage: ./notify -i <IP to connect to> -p <port to connect"\
        " to -f <FIFO file to read from> -m <message to search for in log>\n");
int main(int argc, char **argv)
    int fd;
    int opt;
    char *ip;
    uint16_t port;
    char *fifo_file;
    char *message;
    int tmp;
    struct callback_info ci;
    ip = fifo_file = message = NULL;
    port = 0;
    while ((opt = getopt(argc, argv, "i:p:f:m:")) != -1)
        switch(opt)
            case 'i':
                ip = optarg;
                break;
            case 'p':
                tmp = atoi(optarg);
                if (tmp < 0 || tmp > UINT16_MAX)
                    DIE("please provide a proper port number\n");
                port = (uint16_t)tmp;
                break;
            case 'f':
                fifo_file = optarg;
                break;
            case 'm':
                message = optarg;
                break;
            default:
                print_banner();
                exit(EXIT_FAILURE);
    if (ip == NULL || fifo_file == NULL || port == 0 || message == NULL)
        print_banner();
        exit(EXIT_FAILURE);
    ci.message = message;
    ci.addr.sin_family = AF_INET;
    ci.addr.sin_port = htons(port);
    if (inet_pton(AF_INET, ip, &ci.addr.sin_addr) < 0)
        DIE("Invalid IP address\n");
    if ((fd = open(fifo_file, O_RDONLY)) == -1)
        DIE("Cannot open fifo file\n");
    iv_init();
    IV_FD_INIT(&(ci.fifo));
    ci.fifo.fd = fd;
    ci.fifo.cookie = (void*)&ci;
    ci.fifo.handler_in = fifo_callback;
    iv_fd_register(&(ci.fifo));
    iv_main();
    iv_deinit();
    return EXIT_SUCCESS;
#include <stdio.h>
#include <fcntl.h>
#include <stdlib.h>
#include <unistd.h>
#include <stdint.h>
#include <string.h>
#include <iv.h>
#include "usbrelay/libusbrelay.h"
#ifndef BUFSIZE
#endif
#define CONNECTION_TIMEOUT (10)
struct ring_timeout
    struct iv_timer timeout;
struct connection
    struct iv_fd fd;
    struct iv_timer disconnect_timeout;
struct listening_socket
    struct iv_fd fd;
int ring_time;
char *relay_name;
unsigned char relay_offset;
static void turn_relay_off(void *_rt)
    struct ring_timeout *rt;
    rt = (struct ring_timeout*)_rt;
    /set the relay state
    if (operate_relay(relay_name, relay_offset, CMD_OFF, 0) < 0)
        fprintf(stderr, "Error turning the relay off\n");
    free(rt);
static void connection_handler(void *_conn)
    int len;
    char buf[BUF_SIZE];
    struct connection *conn;
    conn = (struct connection*)_conn;
    if ((len = read(conn->fd.fd, buf, sizeof(buf))) <= 0)
        if (len < 0 && errno == EAGAIN)
            return;
    if (strstr(buf, RING) == NULL)
        goto out;
    if ((rt = malloc(sizeof(*rt))) == NULL)
        fprintf(stderr, "Out of memory, making some space, closing conn\n");
        goto out;
    if (operate_relay(relay_name, relay_offset, CMD_ON, 0) < 0)
        fprintf(stderr, "Error turning the relay on\n");
        goto out;
    IV_TIMER_INIT(&(rt->timeout));
    iv_validate_now();
    rt->timeout.cookie = (void*)rt;
    rt->timeout.handler = turn_relay_off;
    rt->timeout.expires = iv_now;
    rt->timeout.expires.tv_sec += ring_time;
    iv_timer_register(&(rt->timeout));
out:
    iv_timer_unregister(&(conn->disconnect_timeout));
    iv_fd_unregister(&(conn->fd));
    close(conn->fd.fd);
    free(conn);
static void client_timeout_expired(void *_conn)
    iv_fd_unregister(&conn->fd);
    close(conn->fd.fd);
    free(conn);
static void listening_socket_handler(void *_ls)
    int fd;
    socklen_t addrlen;
    struct listening_socket *ls;
    ls = (struct listening_socket*)_ls;
    addrlen = sizeof(addr);
    fd = accept(ls->fd.fd, (struct sockaddr *)&addr, &addrlen);
    if (fd < 0)
            return;
        perror("Error accepting: ");
        exit(EXIT_FAILURE);
    if ((conn = malloc(sizeof(*conn))) == NULL)
        fprintf(stderr, "Out of mem\n");
        close(fd);
        return;
    IV_FD_INIT(&conn->fd);
    conn->fd.fd = fd;
    conn->fd.cookie = (void*)conn;
    conn->fd.handler_in = connection_handler;
    iv_fd_register(&(conn->fd));
    /in case of connection timeout
    IV_TIMER_INIT(&conn->disconnect_timeout);
    iv_validate_now();
    conn->disconnect_timeout.cookie = (void*)conn;
    conn->disconnect_timeout.handler = client_timeout_expired;
    conn->disconnect_timeout.expires = iv_now;
    conn->disconnect_timeout.expires.tv_sec += CONNECTION_TIMEOUT;
    iv_timer_register(&conn->disconnect_timeout);
    fprintf(stderr, "Usage: ./notify -p <port to listen on> -n <port name of"\
        " the relay> -r <ring time, time the relay is open in seconds>"\
        " -o <offset of the relay on your board>\n");
    int fd;
    int opt;
    char *ip;
    uint16_t port;
    int tmp;
    struct listening_socket ls;
    ip = relay_name = NULL;
    port = 0;
    relay_offset = 0;
    while ((opt = getopt(argc, argv, "p:n:r:o:")) != -1)
        switch(opt)
            case 'o':
                relay_offset = atoi(optarg);
                break;
            case 'p':
                tmp = atoi(optarg);
                break;
            case 'n':
                relay_name = optarg;
                break;
            case 'r':
                ring_time = atoi(optarg);
                break;
            default:
                print_banner();
                exit(EXIT_FAILURE);
    /need to do this once
    enumerate_relay_boards(getenv("USBID"), 0, 0);
    if (port == 0 || relay_name == NULL)
        print_banner();
        exit(EXIT_FAILURE);
    if ((fd = socket(AF_INET, SOCK_STREAM, 0)) < 0)
        perror("Error creating socket: ");
        exit(EXIT_FAILURE);
    /setup socket stuff
    addr.sin_addr.s_addr = htonl(INADDR_ANY);
    if (bind(fd, (struct sockaddr*)&addr, sizeof(addr)) < 0)
        perror("Error binding: ");
        exit(EXIT_FAILURE);
    if (listen(fd, 4) < 0)
        perror("Error listening: ");
        exit(EXIT_FAILURE);
    iv_init();
    IV_FD_INIT(&(ls.fd));
    ls.fd.fd = fd;
    ls.fd.cookie = (void*)&ls;
    ls.fd.handler_in = listening_socket_handler;
    iv_fd_register(&(ls.fd));
    iv_main();
    iv_deinit();
	At least for me, the doorbell problem is solved.
Sorry for late answer.@sp00025 you speak about “it sends a message to MQTT server using its POE connection and then it is possible to trigger any suitable sound device.” how did you configure this sending messages to you MQTT server or how is this working?
I would not try 48 volts directly. I use my poe switch 48v with a 12 volt inline converter.Sorry for late answer.
I have a solution for getting a keypress from npc app similar to described here by @mrxyz.
This also involves a full busybox placed on a SD Card and reredirect. Only, I parse the output for a string "keyup = 2", or just keyup.
Furthermore, I compiled a few more tools including mqtt_pub which is doing the job.
If anyone can advice, if the POE used in this doorbell is compatible with the standard 48V 802.3af? All info found is that it is a 24 or 36V max, and no standard type mentioned. If connect it to a POE switch instead of a provided POE splitter with 12V power supply will it burn?
This has all been discussed previously in this thread. The doorbell is not 802.3af compatible, it uses passive PoE. In principle if you connect it to a 802.3af switch it should not get any power at all as it won't get through the negotiation phase. Feeding it with 48V is likely to damage the unit either instantly or in the long run. There's a device from Ubiquity that basically turns an 802.3af powered port into passive which is what I use. All details somewhere in this thread, try searching.
Thanks a lot for the info. Indeed, searching this thread more, I found very useful info, for example how to get a 433MHz signal from keypress and its encoding. That definitely needs a try.I would not try 48 volts directly. I use my poe switch 48v with a 12 volt inline converter.
Regarding the POE discussion, I realized that it maybe not useful at all in many installation, as powering a doorbell with POE makes impossible to unlock the door... as follows from the user manual.
You are right about cloud-connection. Even it is easy to block, you loose all the useful services.Don't remember reading that but in any case I'll be damned if I would ever allow a cloud-connected IoT device to open my front door. Not gonna happen.
So, you are not able to open door remotely, you can only see and talk to a visitor. I found a problem with yoosee app - it misses rings on android, so remote interaction is not an option for me. I have a doorbell on the entrance door, but to the garden not to the house. So sometimes it is useful to open remotely for a postman to leave a parcel inside.
At the moment, the doorbell integrates nicely into Synology using onvif, but it is not working for sending sound other way. It also integrates into a smart home system. But for remote use with mobile, before I can totally cut cloud services, i need intercom and unlock features. What my doorbell currently does -- it sends a snapshot of a visitor to Slack or Telegram on a ring. This notification comes realtime. Further work is needed, but Telegram API looks promising, and recently they start supporting video calling on mobiles. I am now experimenting towards that...
