mqtt:
  host: 192.168.1.110
cameras:
  entrance:
    ffmpeg:
       inputs:
        - path: rtsp:/admin
[email protected]:554/onvif2
          roles:
            - detect
            - rtmp
            - record
    detect:
      width: 1920 # <---- update for your camera's resolution
      height: 1080 # <---- update for your camera's resolution
      fps: 15
    # motion:
      # mask:
        # - 192,1080,194,80,1920,84,1920,0,0,0,0,1080
    # hwaccel_args:
      # - -hwaccel
      # - qsv
      # - -qsv_device
      # - /dev/dri/renderD128
detectors:
  cpu1:
    type: cpu
  cpu2:
    type: cpu
record:
  enabled: true
  retain_days: 0
  events:
    retain:
      default: 10
ffmpeg:
  # Optional: global ffmpeg args (default: shown below)
  global_args: -hide_banner -loglevel warning
  hwaccel_args: []
  input_args: -avoid_negative_ts make_zero -fflags +genpts+discardcorrupt -stimeout 5000000 -use_wallclock_as_timestamps 1
  # Optional: global output args -rtsp_transport udp
  output_args:
    # Optional: output args for detect streams (default: shown below)
    detect: -f rawvideo -pix_fmt yuv420p
    # Optional: output args for record streams (default: shown below)
    record: -f segment -segment_time 60 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
    # Optional: output args for clips streams (default: shown below)
    ##clips: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an
    # Optional: output args for rtmp streams (default: shown below)
    rtmp: -c copy -f flv
