Yea, But, they sponsor Ferrari in F1. So my money went to some tires several races ago.
 same got my 3.6 and 2.8 but need to get off my ass away from the pc to set them upGoing to look at putting together a comparison between 2.8 and 3.6 when I get my hands on both prod models. That way people will get an appreciation of a) focal length in the real world especially with these more shallow depth of field sensors + b) an update on the issues I noted that were meant to be tackled in Prod. Will keep all updated. Also working on the A180 cam bugs to try and get that moving forward for a new bug release from Dahua and can then review that
Full color all the time. LEDs can be set to trigger on motion BUT I would advise constant light source either on or off camera so you don’t suffer fromHow does the color night recording work?
Does the spotlight come on when it detect motion and it records in color?
OR
It is on all the time to get color night recoding?
Thanks
light bloom or potential missed target captures as many of us have mentioned here before.
I'll try and do a 2.8mm vs 3.6mm 4K-T AND add in the 3.6mm 4K-X for good measure. If I can pull that off they won't all be sitting next to each other, will have to have the 4K-X off to the side but would be close enough to show any differences. I'll work on that as soon I get my hands on the units and let you all knowCan you do another 4kx vs 4k-t comparison withg the new firmware?
Be interesting to see how PQ and DOF compare following the changes. I'm sure many want to get onto the 4kt but atm have some doubts given it's performance doesn't quite match the x. Hoping Dahua have either fixed it or can level the playing the field in the future.
Also, hooping we might see a varifocal 4k-t in the not too distant future.
The varifocal will be a while IMO, I wouldn't hedge bets on it being available soon. If you have a need now then picking up the current turrets is the way go.Is there any ETA on the varifocal model? Debating if I should wait or just pick up one of the 2.8mm or 3.6mm. I do like the ability to zoom in order to dial in the picture exactly where I want it though.
With my 5442t-ze i had the camera set to DAY/NIGHT profile management, so my settings for night and day would automatically change when needed. This worked well. Maybe I'm blind, but how do i get these settings in the new GUI. I'm a little lost to be honest.
According to page 15 of the Dahua web 5.0 manual, there is a day/night switch for the camera like the older Web 3.0 has.
@EMPIRETECANDY Can this feature be added to your firmware?
