Kelsiferous
ok setting up substreams made it workable
well, im sorry for so many posts, i got it to work i thought but yeah, if someone can offer me any advice i would be most appreciative
Thanks! @Wildcat_1 (dalao)great work, i will get this firmware release and post here for update on Monday.
glad you like it @garycrist. It was a lot of work but glad Dahua followed my recommendations, changes and updates to code as I think this FW now really catapults this camera forward.Getting this KILLER camera dialed in is quite astounding! Thanks to @Wildcat_1 for the work on the up-grade.
My Day time shot shows a high tension line about 1 KM away. Magnify the tower and one may see the power lines too!
Then the night w/ the LED @4 out of %100. See the Big Dipper?
You can either use Dahua standard firmware or the more newly updated ones (with the features, improvements and changes that I and others work on) that @EMPIRETECANDY will then distribute through a thread or direct. I just approved the 4K-T FW last week that I had worked on and had Dahua implement a ton of improvements on. I would highly recommend that one.I received my first IPC-color4kT-2.8 Andy on tuesday, and am curious to how upgrades go? I assume I should stick with the custom firmwares, but how are those posted/downloaded? I notice an update button in one of the menus, does that check for the proper firmware? Or do I just wait to see a post here/somewhere else to download and manually update the camera? TIA!
Just send you a DM for the new fw, try to upload on the forum, but the forum shows some mistake when upload to 100%, i already contact admin to help this out.I received my first IPC-color4kT-2.8 Andy on tuesday, and am curious to how upgrades go? I assume I should stick with the custom firmwares, but how are those posted/downloaded? I notice an update button in one of the menus, does that check for the proper firmware? Or do I just wait to see a post here/somewhere else to download and manually update the camera? TIA!
I've watched this thread for a while, I appreciate the effort you have put into this! I'm sticking with @EMPIRETECANDY firmware. Thx for the 411!You can either use Dahua standard firmware or the more newly updated ones (with the features, improvements and changes that I and others work on) that @EMPIRETECANDY will then distribute through a thread or direct. I just approved the 4K-T FW last week that I had worked on and had Dahua implement a ton of improvements on. I would highly recommend that one.
Got it! I've installed it and all seems well, can't wait to get the camera installed but that will be a month or so. Thank you so much!Just send you a DM for the new fw, try to upload on the forum, but the forum shows some mistake when upload to 100%, i already contact admin to help this out.
have to wait around 2 weeks.Any word on black model?
Well it is from Russia! Kaspersky that is.Kaspersky complains too...![]()
