catcamstar
- Jan 28, 2018
- 1,656
- 1,196
Reconfiguring my BI server since the SSD took a dump, I just need a quick confirmation:
for the VPN on my Netgear R7000, I just port forward the router to BI Server correct?
Keep it at port 81 by default? when would you change the port number?
UPnP is also disabled and BI app works on my android phone.
I was reading through the BI4 help file and wizard and it says to enable UPnP... is it just because it is easier and more so for LAN use?
It's been a while since I touched the networking stuff since I first set this up originally.
Interesting post. Not sure if the concept of VPN is crisp and clear, but in two words:
- VPN client runs on your phone/tablet
- VPN server runs on your Netgear router
- VPN client connects to your VPN server and is "transparantly" connected to your home LAN
- Absolutely no port forwarding or UPnP is required with such a setup
My advice: disable port forwarding on your router and any UPnP configurations.
Good luck!
CC
