My DB1C RTSP feed to Blue Iris drops out every few minutes for about 20sec each time. It's really annoying. Interestingly though, running VLC Player on the server connected to the RTSP stream I noticed that the stream stays solid (same on the EZVIZ app too) when the BI feed drops out which seems to indicate that at least the DB1C isn't rebooting. BI Support have suggested some things but nothing has fixed it so far.
Would be interested to know if your RTSP stream keeps running on VLC or EZVIZ app when you notice the drop out on your Synology.
About 2 weeks ago I got a new router and moved it to a slightly better position than the last one. Since then the Synology logs show only one dropout which lasted less than a minute. VLC has been reliable whenever I checked it. I'm using the 2.4GHz channel now where before I was trying to use 5GHz. Speed tests (using my phone) showed great performance at the doorbell location on 5GHz but it makes sense that 2.4GHz would be more reliable. The higher frequencies would have more signal attenuation with distance and be more affected by objects in the path.
I'm using these settings in Batch Config. I think all I changed from default was H265 -> H264 and 15FPS -> 10FPS.
