Oh well, another useless download.
Whatever would make you think that?It started doing that about six months after it was installed. The point being that failure in that short a time, and out of the return period, just isn't acceptable. Then again, it's a piece of consumer level junk in the first place. I had hoped for better, but got worse. Simple answer for me is that unless it's PoE it's just not going to be used on my system.
Do you know of any url that's a trigger when the button is pushed?I've already got it configged the way I want it. I need an app that responds when there's a button push. I know it's P2P and what that can lead to in terms of security, but it would be nice for her to have, too.
It would be useful for me because I could use hubitat to send a command to my blue iris..
Thank you
That won't work for me.. I need a http url so I can use it in hubitatYou could check this out - worked for me: Getting Ezviz DB1 (or Hikision or LaCie) doorbell presses
Many people use a Relay...We have a list on our 101:That won't work for me.. I need a http url so I can use it in hubitat
I've been recording my db1c rtsp stream on my Synology NAS for a few months but recently I've been having a lot of disconnects. After reading this thread I've just used the Hikvision batch config tool to change from h265 15FPS to h264 10FPS. I kept the bitrate at 2 Mbps for now.
I'll update in a few days
EDIT: Well it was good for about 12 hours but in the next 12 hours I had three ~30-minute long dropouts.
Hello @silencery,
I wonder if you can help - I notice that your review video of the DB1C footage has audio in BI...
My DB1C has never got audio in BI (though audio comes through in the EZVIZ app and when viewing the stream in VLC) despite my selecting the audio option when adding the camera.
I wondered if you'd be able to share the settings you've used in BI?
Thanks!
I would try this, from your box running Blue Iris do a continuous ping to the DBC1 to see if you have a network issues.My DB1C RTSP feed to Blue Iris drops out every few minutes for about 20sec each time. It's really annoying. Interestingly though, running VLC Player on the server connected to the RTSP stream I noticed that the stream stays solid (same on the EZVIZ app too) when the BI feed drops out which seems to indicate that at least the DB1C isn't rebooting. BI Support have suggested some things but nothing has fixed it so far.
Would be interested to know if your RTSP stream keeps running on VLC or EZVIZ app when you notice the drop out on your Synology.
Feel free to check out our 101, there are a lot of good tips that also apply to the DBC1:My DB1C RTSP feed to Blue Iris drops out every few minutes for about 20sec each time. It's really annoying. Interestingly though, running VLC Player on the server connected to the RTSP stream I noticed that the stream stays solid (same on the EZVIZ app too) when the BI feed drops out which seems to indicate that at least the DB1C isn't rebooting. BI Support have suggested some things but nothing has fixed it so far.
