I ordered a 5442-ze last night.
Yea, wifi is something I've known I wanted to avoid. I know about vivint too, their sales tactics, etc. It must be quite easy to install their systems (I watched a couple videos way back when I was early in my research. Heard some bad stuff about them). I have 'studied' the cliff notes, most/many parts of it anyways. Excellent resource.
Wifi is pretty bad. I've had a Eufy camera "2C" kit (three of the 2C cameras) for probably close to two years now. 1080p resolution (HAH!), they're garbage. I won't even bother to go into just how trash they are; trash app as well. But I did not get them for home security. They were bought for the sole purpose of monitoring rodents and rodent traps, and they're barely sufficient for that purpose.
I would never recommend them to anyone for security/surveillance of their home.
As for the face ID, these days criminals can walk around freely with a face nappy and a hoodie on and blend right in, in which case you're not getting a facial ID regardless of camera quality. Right? This is another reason why I actually think, in my case at least, that an actual "home intrusion alarm" system is a better thing to have than a camera system. What do you guys think about that? Is there a discussion on that concept here anywhere?
Alarm grid just replied to my question regarding wanting to learn about these diy home alarm systems with a few links to some blog posts and other info on what they said are their more popular systems. So I'll have to make some time to look over that too.
Thanks again.
PS: I caught some 'action' on a eufy cam last year. Maybe I'll post a clip for people to see. Maybe in that "consumer grade camera" threads.
That's probably the case.In all likelihood it is a 2.8mm wide angle see everything type camera that is on a less than ideal MP/sensor ratio (camera spec probably just says 4K with no mention of sensor size) that will simply let them know what time something happened....maybe...wifi tends to go out with motion.
Ok, thank you.It is totally fine having your first camera be an overview OBSERVE level camera but you should get a good one so that you stand half a chance of at least finding something that could ID someone - skin color, clothing, etc.
This was one that I made note of, actually, I made note of most if not all of what you're saying. Having only one camera to start off with is gonna be tricky though, haha. Might have to just be a "there's movement in the back yard" type of use, to start off with. As well as a possible visual deterrent...First mistake with new cam owners, is they try to do too much with one particular camera.
Thanks again.
