sebastiantombs
Andy has his ways with shipping, you may be surprised.  No guarantee on that though, he may not too.
 Yes, I haven't ordered anything in a while and I remember him posting that shipping was going up. I still think shipping won't be unreasonable.Andy has his ways with shipping, you may be surprised. No guarantee on that though, he may not too.
Am I right in thinking that two drives are better than one? That's what I've gathered from reading some threads involving blue iris hardware.Generally speaking, unless the installed RAM is throwing a lot of errors you're fie with whatever comes in the machine. Ram isn't as expensive as it used to be so upgrading to 16 or 32GB might be in your budget.
That i7-7700 looks pretty decent. You will want a surveillance rated drive, Western Digital Purple or Seagate Skyhawk, no matter what one you buy. I'd shoot of 8TB because more is always better and cameras do seem to multiply like rabbits. I started with a 4GB and ran out of room in a rush. Now I've got that 4GB and an 8GB and plan on another 8GB early next year, if not sooner.
I've heard several similar warnings about dome style cameras. And I keep coming across more posts saying the same. So it's really making me want to avoid that style.TonyR Tips:
Use turret style for best results (bullets have issues with spider webs, domes can have issues with glare and IR bounce backs as dome can get fogged by moisture and dust)
That all depends on your cameras. The total budget on all 8 ports is 65 watts for the one you linked to. I'd have to look at the numbers on whether that's cutting it close if these cameras have infrared. If you want to be on the safe side get one with a larger total amount allowed. This one IPCamPower POE Switch (4, 8, 16 & 24-port) - IP Cam Talk Store for the 8 port version allows a total budget of 130 Watts. That should be sufficient even if you are running all 8 as PTZs with IR (which nobody does).Is this an appropriate POE Switch guys?: LINK
edit: spelling.
Thanks. I was about to order it.That all depends on your cameras. The total budget on all 8 ports is 65 watts for the one you linked to. I'd have to look at the numbers on whether that's cutting it close if these cameras have infrared. If you want to be on the safe side get one with a larger total amount allowed. This one IPCamPower POE Switch (4, 8, 16 & 24-port) - IP Cam Talk Store for the 8 port version allows a total budget of 130 Watts. That should be sufficient even if you are running all 8 as PTZs with IR (which nobody does).
And, I'll just say that if you think you are going to want 8 cameras, get a POE with 12 or 16 ports. If you plan to have 8 cameras, you'll find that you'll actually need (or want) more...That's what I came to, and it's a common theme around here.
Thanks for the canadian amazon link, hah. The model you linked says 13 port w/ 8 port poe+, but the images all show only 8 ports (and two uplink ports, with a third uplink port that looks different).yeah its ok. But like Ethernaught said,,,,,you'll wish you had a couple extra ports.
You have 24 cameras in your condo/apartment!? What?I went Bonzo and got a 24 port Cisco for the Condo.....but now I wish i woulda went 48.
