I checked the firmware, their HWIDs are still 5x49, not 5x59. I can confirm that the sensor used in 8MP model is SmartSens SC850SL, which is quite good from my experience
but it's 2021 image sensor.. taken from HIK ColorVu 2.0 cams..
As I told a few times, all progress in 2024/2025 Dahua WizColor / HIK ColorVu 3.0 cams are based only on new SOC with AI-ISP video processing.
Zero progress on sensor level..
This is very visible from the comments here on the forum, where other participants are struggling with the effects of always-on AI-ISP processing (2D/3D AI Noise reduction)
It's a bit old but already has the best excellent specs, almost 100% QE on visible light band, and 70%+ QE at 850nm. I don't see any sensor with better specs so far.
I have a Dahua Chinese domestic model with this sensor, SoC is Axera AX620Q with the so called AI ISP. I don't believe it, I think the image improvements are from the sensor itself, the ISP has little impact.
I compared it with a model from Anjvision with the same sensor but different SoC, SigmaStar SSC378DE which was born before the AI world. From my testing, there's little difference in ultra low light environment, the noise and the ghosting
This 'always on' processing needs to stop or at least have a toggle for those who don't want the 'we think we probably know what you want so tough luck' option turned on! I am seeing this on the 54Pro and wish it could just be disabled for more natural viewing.
While we are on this auto processing discussion, why do camera manufacturers insist on auto settings having shutter way too slow. As we know, having a nice picture for the brochure or website is all well and good, but sadly the criminals do not pose for portrait shots in the dead of night! At least maybe set shutter speed to 1/100 or 1/80, at least that would give beginners a chance without manual settings. Rant over!
I don't think this is possible.
AI-ISP is very different video processing pipeline from classic Dahua/HIK one (I found this one year ago with TIOC-PRO).
It can be tuned (internal Dahua configuration of used SOC) but not switched off.. very similar to full color cams, which had not switchable full color processing..
if you don't like AI-ISP video processing PRO cams are not for you..
You should look at new 5459-IL models, which are PRO models without WizColor (AI-ISP) and with image sensor taken from 5442/5842...
Andy (@EMPIRETECANDY) do you will have any new 5459-IL models to any testing?
There is a reason for the movie industry spending lots of time and money on lighting equipment and people to haul it around, along with the generators and cables to run them for the past 100 years. Natural light, electric or reflectors, there has to be enough light to capture images. And much more for color. Considering this the quality of the images you guys are producing is pretty fantastic.![]()
0 Sharpness , nr : 5 , Shutter 4 , Gain 69
but have then had to up the gain to compensate
. The problem probably is your camera can't manage a bright enough picture in full colour with that light level with bot acceptable shutter and gain. You could try tweaking it slightly by dropping shutter to 6ms and gain to 50, but still no guarantees. At the extreme try 8ms / gain 50 but then you are on the edge of seeing shutter related issues with fast movement.The difference has nothing to do with the ISP, it's because of the lens aperture, F1.6 vs F1.0.In comparison to classic IR 1/1.8" image sensor with F1.6 aperture cams with classic processing (like Dahua 5442) the difference is bigger..
There are sensors that can see. The problem is they don't seem available to the CCTV industry or available at the right price. The one camera we saw that could function in the dark very very well was @$10k once a lens, heater, casing, wipers etc were added. It had to go right up to a 35mm sensor to achieve it. That said the results were sublime. Some have suggested it used the Sony a7ii sensor / processor.
I did do the comparation using same F1.0 lens and same sensor SC850SL, but different SoC. What really matter are always the sensor and lens. The ISP has little impact. The so called "AI ISP" is just a marketing trick, everything must be "AI powered" in the current AI age
To compare the difference, you need to manually set them with the same shutter speed and gain value. Or they sure will have the same bright image when there’s enough light.I had F1.2 aperture (almost F1.0) 5442H versions (in 7442 chassis/optics) and the difference in image brightness at night wasn't huge...
Yes, at this current stage, I only believe in sensor and lens size. Modem ISP and algorithm may help a lot in taking still photos, like deep space photography, but not that much with moving videos, like CCTV
AI will have an effect. It can be used to remove the jaggies and sharpen images including text. It can also be used to apply colour / light correction essentially output a raw file then apply a realtime adjustments. I'm not saying the latter is how it handles lighting, but it's certainly within the realms of possibility. Text enhancement / jaggie reduction is almost certainly going to be a given on a camera labelled to have AI.
The effect of Aperture is to enhance depth of field. I wouldn't expect to see a difference in jaggies just blur based on dof. Given there's no difference in zoom, the Jaggies are almost certainly the result of processing artefects and the fact they're reduced / missing on the AI camera suggests it's processing them out by either more intelligent use of the codec or interpolation of the missing pixels to smooth the image.
Thanks to @steve1225 and others with far more knowledge than me on the details of the technology. It’s becoming clear this has a very different animal.
After the 2nd night of what I thought would be fairly simple testing like I’ve done hundreds of times, I’m still perplexed at the digital noise in low light.
It’s clearly different than we’ve seen with the 5442 series.
*note I’m talking about human/vehicle/critter movement in motion video. Still shots are awesome but alas meaningless.
Daytime is great. With some rather odd (compared to the 5442) settings and with with the “HDR” effect you can achieve some very good dynamically rich images. Deeper colors, better shadows, more brilliant, better perceived depth, and rich.
And at night with enough light, (as seen in my back door install) it can perform quite well.
But turn out the added off-camera lights at night in a dark to semi-dark scene and I’m really struggling with the fuzzy digital processed noise vs blur.
As there are few nighttime videos posted so far with low light, @Chokolinho
