Rgs
Does ZeroTier require much overhead when running and not using in the background? I know that if you use Teamviewer set to autoconnect you have a lot of overhead.
I have been using BI for a while and just found out about ZeroTier. Set it up a few days ago. WiFi working fine, but I couldn't get my android phone working away from the house. Walked through settings multiple times, no joy. Then started walking through step by step and discovered I entered the BI Server physical IP address from the ZeroTier site, and not the Managed IP address. Use the Managed IP address and you will be much happier.
There's a link to his original Zero Tier tutorial in his newer "Is Someone in My House?" remote access video.
I tried the vpn and zerotier methods of which neither would connect to Blue iris away from home, you really don't need a video per say with tailscale. If you can get the connection over wifi at home, tailscale is just a matter of downloading and connecting per their instructions. IE connecting 2 nodes, sharing 2 nodes. It is very simple. The only difference of in the house and on the road is turning it on, on my phone, then opening BI.Is there a video re connecting Blue Iris to Tailspin as there are several about connecting BI to Zero Tier?
I did everything under the sun and would only get a connection sometimes, and then maybe, maybe not the videos would load. worked on the vpn for a month, zerotier for 3 weeks, tailscale was immediate. Have a new phone now so don't know if that would have made a difference, but it aint broke so I won't fix it lol.What is the issue you are having? Did you check windows firewall and see if PUBLIC is enabled?
I appreciate your willingness to help. I think there is a bit of confusion here. I'm no longer trying to use zerotier, finished with that over a year ago. Totally aware of all the trouble shooting of ip addresses, web server, etc. It simply would not work at that time. With tailscale working so easily I see no reason to go back to a different method. My router supports open vpn but I simply couldn't get things to work consistently. Tried everything I could find everywhere on both methods, a lot of reading and videos. Again, appreciate your help but I'm not having any problems with tailscale so I see no reason to try to change it. Just have to open the app to use it.Make sure your using the zerotier address assigned to your blueiris pc and not the computer lan ip address . I once had them change on me for some reason.
Also make sure your settings under "Web Server" that you dont have bind exclusively checked.
Aww got ya! Tailscale is the best. I just hate it sometimes asking me to relogin when I use the app on my macbook.I appreciate your willingness to help. I think there is a bit of confusion here. I'm no longer trying to use zerotier, finished with that over a year ago. Totally aware of all the trouble shooting of ip addresses, web server, etc. It simply would not work at that time. With tailscale working so easily I see no reason to go back to a different method. My router supports open vpn but I simply couldn't get things to work consistently. Tried everything I could find everywhere on both methods, a lot of reading and videos. Again, appreciate your help but I'm not having any problems with tailscale so I see no reason to try to change it. Just have to open the app to use it.
One video with quite a bit of usefull info about TAILSCALE can be seen atIs there a video re connecting Blue Iris to Tailspin as there are several about connecting BI to Zero Tier?
discuss.zerotier.com
