mephisto_uk
Increased from 6 to 20MB, still the camera freezes from time to time in BlueirisDid you try increasing the receive buffer ? Something to try anyway. 20MB is max. you should try according to manual.
Is this camera's data at anypoint running through a router?Exactly same problem I have here with the camera going no signal. I'm trying to compare to web interface. I wonder if this is related to one of those setting like "keep alive" that I know can be problematic with some cameras
The camera and the BI pc should both be plugged into the same POE switch.
Then another line from the POE switch should run to the router.
Cameras and BI on the same VLAN, no routing on firewall in between them. They are not on the same switch, they are using uplinks, the network topology is fine and I monitor the network ports for traffic so I can easily gauge if there is congestion, plus the CCTV VLAN has priority over other VLANs.
I've even increased the camera to 16000kbit and used the ROI to create some areas of high quality and the camera shoot up all the way to nearly 35000kbit, still worked okay with no congestion or packet loss. I decided to lower the substream1 bitrate from 2048 to 1024, so far no freezes. Not sure what is going on, but definitely not network related as otherwise it would cause problem to 2 other cameras connected to the same switch.
I'll see how it goes and then put the substream1 back to 2048 to see if I can reproduce the problem.
What about other settings - are you maxing out the rated spec by running 30FPS, etc.?
I’m trying to get IVS to work with this camera. I setup all the rules but I can’t get camera to trigger.
okay, I got it to trigger (new GUI). But, I’m not getting any saved alert/recording or push notification. I have it set to “camera’s digital input or motion alarm” only. Any Idea on what I could be doing wrong?
Yes. I have “get ONVIF trigger events” checked. I also increased buffer to 20mb and have “send RTSP keep-Alive’s” and “Use RTSP/stream time code” checked.Did you tell it in BI to pull ONVIF triggers on the camera setup page where you put in the IP address and user/password?
HTTP Get / request...Re run the find/inspect in BI and post a screenshot of the pop up window. I am thinking you have a "bad response" line in there due to on ONVIF conflict.
Okay. I’ll try to update the firmware. I’v never updated firmware on any of my cameras. I was always afraid ok bricking oneThat all looks right.
Did you update to the latest firmware? If not I would suggest try that.
And we have seen some weird things with this GUI that a factory reset solves, so I would say give that a try as well.
Okay. I’ll try to update the firmware. I’v never updated firmware on any of my cameras. I was always afraid ok bricking one![]()
Is anyone using this camera in Blue Iris? I've noticed it often stop responding to Blue Iris and it seems to be performing a soft restart. I've noticed the FPS drops and then it stops responding. I'm running it at 15 FPS, Key 1 (i-frame 15) at 8192 kbit bitrate. Barely any CPU use in blue iris as I do H264 direct to disk. All other 5442 cameras are working just as fine. Just wondering if this is camera or BI related, most likely config related I guess...
I had a very similar issue with this camera, getting many "NoSignal" errors in BI. I do not have AI Enabled in the camera, just IVS tripwire/intrusion rules because I also use a Dahua NVR. I found that when I switched from using Substream 2 to Substream 1 the problem went away. I also only run all cameras at 10 FPS. I have to believe it's more a way BI polls the camera for a response than it is a network/POE issue. The previous cam on this port, worked fine. I also don't get any errors on the NVR for loss of signal.
Hey buddyIt took awhile and I was willing to wait, but I finally got the black version. I think it looks really cool and is a great option for those with dark or black areas that you are going to hang the camera.
My first order of business is to flash the new firmware on it and then I am going to bench test it overnight in BI with a known good short cable and a known good POE+ injector to see if I experience the No Signal errors and FPS drop outs that some others have seen with their system.
