Once again you're expertise and professional production blows every other reviewer out of the water! If all reviews were done at this level it would take all, well almost all, of the guesswork out of selecting cameras.
Which, in your judgement, has the better color rendition at night? The 4K-X or the 4K-T?
As an aside and out of nothing more than curiosity, is that an air connection or hose connection on the side of the house?
Thanks again for a really great review!
Thanks for the kind words as always @sebastiantombs, I really do appreciate it. A lot of work goes into this reviews but my hope is exactly what you mentioned which is that it helps to 'take all, well almost all, of the guesswork out of selecting cameras'. I also try to show most features (where possible) and for the important night testing give everyone an idea of how these will perform under different lighting situations at an install as well as how to dial in the camera for best results. I intend to do more of the 'special feature' walk throughs in the future as well, especially since there are more new features coming to cameras just around the corner
In answer to your question about color, both the 4K-T and 4K-X are very good. The 4K-X has the benefit (at the moment in comparison to this pre-production unit) of having the slightly cleaner image. However in using these cams (2.8, 3.6, 6.0 of 4K-X + the 2.8 of the 4K-T) for a long period, the output from the 4K-T does have the edge in my opinion. Now, I caveat that with the fact that I definitely want you all running the FW I've been working on (once released by Dahua in final version) and dialing in for the FOV but I'm actually really impressed (as I mentioned in the video) with the performance of this Turret so far. As I mentioned above, I believe I've dialed this in (both settings wise + in changes to the underlying code& algorithms) to about the extent I can push this SOC BUT it handles it well. I was pleasantly surprised at how bright the image looks from the 4K-T without being overexposed at night and critically, retaining details. Don't get me wrong, Close Focus Distance needs to be corrected (and I had confirmation late yesterday that it has been on production lines now) + would be great to have a turret with varifocal + speaker (both of which I believe will come in the future) BUT right now have a 1/1.2" sensor in a turret with full color in 4K and delivering an image like this from the Taurus chipset is VERY encouraging.
HTH
