I am with you, not sure it's purpose, I hope it is not gaining access to gather content for some kind of data storage/sell. IPCT ends up on the search engines for good reason, most who help the members here are also helping non-members when they search for solutions/answers online.I don't get the bot thing. Wow.
I remember installing my first ceramic brakes, actually they were part metal too, was told they last longer. Will say I like ceramic, they are cooler and no brake dust. Funny but I too have taken a few power naps under my vehiclesNow that we are past the bot drama, let me share with you some of the stupid mistakes I have made recently.
About 2 years ago, I changed my brake pads. Thought I did front and back. Key word here 'thought'. Recently my rear wheels rear making a grinding sound/feeling. Because I 'thought' I had changed the back brakes as well (can't believe I was this forgetful) I thought the grinding sound was my bearings/axle. Yeap, I way over thought it. So, I am in my neighbors garage with my truck jacked up (I cannot get my truck in my garage and he is a single, retired school teacher and my friend) and I pull my rear wheels. Holy Mother of Christ! Not only are the pads gone, but a good section of the metal on the brakes is gone as well! And yes, I had one hell of a gouge/grove worn into both of them. Wow, what an idiot. So not only did I have to replace the rear pads, I had to replace both rotors as well. On top of that, the right rear caliper was frozen and I couldn't get the piston back in...so new caliper. This is where I learned how to bleed my brakes. While doing this, I discovered how nasty my brake fluid was and flushed my entire brake system and replaced the dot 3 with dot 4 (lots of reading on tihs subject). Although I didn't need to, I went ahead and replaced the front pads as well...so all four brakes now have ceramic pads on them. Last week, when I was driving home from work at around 75 mph, I had to apply my brakes fairly hard. Yeap. My front end started shaking and shimmering like a hooker on payday. So this Saturday, I am swapping out the front rotors as well. I also drained and replaced the rear differential fluid. This I have never done as well. Easy shit. Actually, really enjoyed it, because when it was draining out, I fell asleep and got in a good 40 minute nap under my rear end!Sunday I am draining and replacing the CVT transmission fluid and filters in my wife's 2017 Nissan Rogue.
I am no mechanic, that's for sure. But I try...![]()
And new Dorman metal housing....
And my mechanic saga continues..... In a County and State far, far away........ (humming the star wars theme...)
If any of you are familiar with the Pentastar 3.6 V6 engine, you will know that it has the oil filter and oil filter housing/cooler on top of the Engine in a valley. And YES, the housing is made of plastic...marvelous Mattel toy shit. Yes, they have a habit of warping, cracking or the gaskets going bad and the oil/coolant leaking out and dripping down the back of the engine, onto the transmission bell, and down. Making one think that your main seal is bad...but it's not...you just have over an inch of oil and coolant pooled up in the middle of the top of your engine. Lovely.
At 60K or so miles, this first happened on my truck, and Dodge replaced it for free. Well, that was then, and now i am at 107K miles. So I said screw that and replaced it with a Dorman all metal housing. If I wasn't as 'round' as I am and certainly not 60, it wouldn't have been so bad. I took a day off from work, and it took me around 10 hours to do it. Not tp bad I would say. However, I am just now recovering, and it is Monday. This sucked. Sucked hard, but I got it done. Didn't know that much oil and coolant could pool up in that area. It can and it did. So fingers crossed that I don't have to do this again. I have been told it is around $1500+ and time without my vehicle if I get it done at a dealership. BTW..now I know why I was running low on coolant. It was leaking into here and burning off.![]()
www.explorerforum.com
That 2002 4.6 sure was pretty and clean 14 years later in 2016! Good job, thanks for sharing.I hear ya brother. All the manufacturers are going with plastic valve covers and intake manifolds. Over time they warp and crack leaving you will fluid and vacuum leaks. The 3rd gen Ford Exploders seem to have the manifold issue as early as 60K miles. If anyone has a 3rd gen on here you can find the process below. While I was in there I changed out the timing chain components, water pump and some other things while I had it torn down. May as well while the engine is all apart.
Somewhere from the time you open the hood to start the work to the point where you have what seems half the engine torn down and you are look at the engine without the chains and gears on you wonder if you are going to have leftover parts when you are done.
Tips for Timing Chain Service on 4.6L V8
I recently completed timing chain replacement on my 2002 Explorer with 4.6L V8 so I thought I'd chime in with some tips and answers for those considering this service. My engine has 150K miles on it and I've always been a stickler for changing the oil every 3,000 miles using Motorcraft 5W20...www.explorerforum.com
Da Wife, "Where did all my paper towels go?"p.s. all those paper towels blocking the ports from dirt, dust and gunk look familiar.
I have a 97 V8 Explorer sitting next to my 92 GT Mustang.
But, let me tell you about our new 22 Edge ST! Just think 162 CID cranking out in excess
of 330 HP without a tune! This thing will outrun a '69 Boss 302 but, I have air, heated cooled seats, bla bla bla.
Oh, did I forget 12 speakers![]()
Gen 2 Nano (2.7L TT) in the F150 has both port and DI.
A PCV catch-can will help solve the carbon problem. I am
investigating adding water meth injection. That and a tune will send
these beasts into the 12s no problem. These Edge/MKX weigh in more
than a F150!
