New memory batteries arrived from Digikey.
New one measured 2.45 volts out of package.
Recall that the torn down PTZ was brain dead without a battery in place. Without battery, the web interface would not appear, but it did ping at 192.168.1.108
It had been about a week without a memory battery on main logic board. Either there is a separate store for the firmware or the SRAM has amazing retention. I'm thinking more likely the former than the latter.
Soldered in new battery and confirmed voltage in circuit was 2.44 volts. So, didn't short out the cell soldering it in. Didn't even pull circuit board from the camera module. There is enough access to desolder/solder in cell with circuit board still attached to camera module.
Thank heavens for my stereo microscope. Those are inch markings on my work mat. Magnification made it simple to do the work, but it is probably doable without magnification, if you have young eyes.
Put PTZ back together and......
Web interface was fully active after boot up. PTZ position were storable and recalled after pulling power and restarting the camera.
Updated its firmware via normal web GUI without issue. (No
TFTP nor UART machinations were needed)
Even imported a configuration file from another PTZ and the imported settings are active.
FULL power IR illuminators and no glitches with PTZ motions. This particular camera did not have that issue, but is currently running with PTZ board from a camera that did have that issue.
So, it seems that little battery is absolutely vital to the camera's proper function.
Unfortunately, weather does not permit pulling one of my Alzheimers afflicted SD49225T-HN's down for a battery replacement.
Will this fix the amnesia problem? This is quite promising.
